Tractor Talk Discussion Forum
John Deere 2030 fuel pump
Fla Farmer
11-06-2007 14:55:16
Need info: fuel pump (connected to fuel filter) on 2030 JD (circa 1972) is leaking. Hasn"t been used much since installation. Part doesn"t seem to fit right (as most parts don"t lately). Fuel line to tank is cut off now, but when I reopen fuel leaks out horizontally across the middle of the pump. Does it need a gasket or is it a defective part and needs replacing? Would appreciate a website address where I could printout a schematic. Advice anyone?
wolfman
11-06-2007 17:26:37
 Re: John Deere 2030 fuel pump in reply to Fla Farmer, 11-06-2007 14:55:16
Maybe off track, but my 2020 seemed to have a leak around the fuel pump gasket and it turned out that the upside-down fuel bowl had a crack and the fuel was running down to the pump region. Replaced the fuel bowl & its gasket and problem solved.
