Tractor Talk Discussion Forum
sealer for intake manifold
n8terry
11-06-2007 20:49:01
I want to use some kind of sealer on the manifold
of my tractor when I install a gasket. I am especially concerned about sealing the intake manifold. What do you guys suggest?
I was told to not use silicone cause it wouldn"t hold up around gas. Will that black permatex work ok?
Kansas Cockshutt
11-07-2007 14:07:29
 Re: sealer for intake manifold in reply to n8terry, 11-06-2007 20:49:01
You are right, silicone and gas don"t mix.
Others are right, if you have perfectly clean mating surfaces and a new gasket then you don"t need anything.
If you want a dressing to help things come apart easier later and to make darn sure you have a good seal try "gasganich" or permatex aviation form-a-gasket (available at NAPA etc). They latter is a brown tar like substance that only needs a small application (read- a little goes a long way)
old
11-07-2007 08:09:19
Well if you feel you just plain need to use something the only thing I would use is copper coat, but thats because most manifolds are both intake and exhaust so heat is a factor
Oldmax
11-07-2007 05:20:13
If surface is good neaver use any kind of goop that just causes more problems .
doogdoog
11-06-2007 23:45:46
Aloha, I had good results with Hi-Tac made by Permatex. I use the spray can for large areas but it is also available in a can with a brush.
Mahalo,
doogdoog
RAB
11-06-2007 23:21:20
That is what the gasket is for!! Unless you have a faulty manifold just the gasket is perfectly adequate. If there is a fault, fix it properly. gasket goo is not really the right way to deal with warped surfaces in this application.
RAB
