Tractor Talk Discussion Forum
changing the hydralic lift piston on a 1948 TE 20 with a new
chrisjensen
11-06-2007 21:19:38
Has anybody changed the originial hydraulic lift piston on a 1948 TE 20 Ferguson which had three steel rings for sealing with a newer style piston which uses a rubber o ring and a leather sealing washer? I've been told that the newer style piston which has the same dimensions as the originial piston does a better job of sealing. the new piston I have is for a Ford NAA. I ordered the piston, o ring,and sealing washer from Yesterday's Tractors . I've ordered a new cylinder as there was a lot of leakage at the hydraulic cylinder end with the hydraulics raised and my bush hog attached to the 3 point. It is my opinion that a rubber o ring would be better at sealing than the steel rings.
Leon R
11-07-2007 07:51:56
 Re: changing the hydralic lift piston on a 1948 TE 20 with a in reply to chrisjensen, 11-06-2007 21:19:38
Chris, About 16 years ago I redid my MF65 by honing out the cylinder with a Sonnen hone and a friend made a new piston to fit, on his lathe and we used an O ring and back up rings, the same as hydraulic cylinders. It is still holding up well.
chrisjensen
11-07-2007 10:32:21
 Re: changing the hydralic lift piston on a 1948 TE 20 with a in reply to Leon R, 11-07-2007 07:51:56
Leon,
Thank you for the information. The new cylinder from Yesterday's tractors hasn't arrived yet. I plan to try the new piston with the o ring and leather back up washer.
Chris Jensen
ejensen@rockisland.com
