Tractor Talk Discussion Forum
Diesel fuel, What's happened here?
S. Crum
11-08-2007 04:52:08
I have a 275 gallon plastic tote tank sitting outside that has about 30 gallons of red diesel in it. This fuel was put in the tank new back in January. I just drew about 5 gallons of water off the bottom of the tank and some pink milky stuff. The tank was clean and dry inside before this fuel was put in and the tank is sealed up so nothing could have leaked in. This tank has set in the sun all summer. Did this fuel go bad, separate, "de-refine" itself? I'd like not to have to put it out as waste oil as it's about $100 worth now and I could use it in the shop furnaces if it's salvageable. Any thoughts?
shannon from ohio
11-08-2007 16:43:52
 Re: Diesel fuel, What's happened here? in reply to S. Crum, 11-08-2007 04:52:08
Diesel fuel is a hydrophylic fluid (Will attract water and moisture).. Draw water off bottom and you'll be ok as long as fuel isn't cloudy..Note, Open petcocks on your water separators and you'll see what i mean..... ....
Mike M
11-08-2007 05:11:48
Where is the bung ? If like a barrel on top they fill up with rain water.
caterpillar guy
11-08-2007 05:04:17
You have water condensation in the tank. You can either just use it in your waste oil furnace, or pour it off into a different tank. I would let it settle and drain the water out the bottom of the tank. The water come from the heating and cooling if you can stabilize the temperature of the tank like putting it out of the sun and giving it a vent it should help this significantly.
Allan In NE
11-08-2007 05:03:42
What Jed said.
Draw off the water from the bottom and then your fuel is as good as can be.
Allan
dej(jed)
11-08-2007 04:59:51
Petroleum has the ability to carry about 1% water. So for 100 gallons you could have 1 gallon of water suspended in it. Water is 2H2O and fuel is C2H4, etc., so the hydrogens can physically bond. When it get super saturated it will appear hazy and then it drops out and forms a layer on the bottom. It phase seperates. the problem with the water is that it allows bacteria to grow. Syphon the fuel off the top, or syphon the water off of the bottom. The red is simply the dye. The fuel should still be useable.
