Tractor Talk Discussion Forum
Hay Wagon Running Gear Hub
Hard Country
11-09-2007 12:36:16
Need to replace the hub of the running gear on my hay wagon. Unable to identify the type of wagon or correct part. The inscription on wheel hub reads CTD and possibly OC13. Anyone have any ideas? Located in Dover, DE.
Leland
11-10-2007 07:23:08
 Re: Hay Wagon Running Gear Hub in reply to Hard Country, 11-09-2007 12:36:16
hubs were made by hundreds of different companys ,just take it to a dealer of farm store they can get you a replacement rather quickly .
Bob
11-09-2007 21:08:40
CTD = Canadian Tool and Die, Winnipeg, MB.
You may be able to find another hub with the same dimensions, or email them and ask who distributes them in your region.
Email is: info@canadiantool.com
Phone is: 800-204-4150 or 204-453-6833.
poogie
11-09-2007 13:26:44
If it has Timken tapered bearings just get the bearing # 's and the number of bolt holes and the size of bolt hole pattern. Then serarch implement parts suppliers to find what you need. There are not a lot of implement wheel bearing #'s
