Tractor Talk Discussion Forum
Lanse! Lanse! Wake up!
hillbillyOH
11-10-2007 04:33:11
$500 Farmall H
North Baltimore looks to be about a three hour drive from Dayton...
Andy Motteberg
11-10-2007 09:59:10
 Re: Lanse! Lanse! Wake up! in reply to hillbillyOH, 11-10-2007 04:33:11
I'd sure buy it if I was closer! New rear tires are probably worth that price!
rustyj
11-11-2007 11:50:07
 Re: Lanse! Lanse! Wake up! in reply to Andy Motteberg, 11-10-2007 09:59:10
There was a nice Farmall for sale, about a month ago, on Rt. 19, about half way between Zelienople and Portersville, Pa. Looked in nice condition. Don't know the price. Don't know if still there. Was near Charlie Burg's place, but not his.
I don't have a name
11-10-2007 09:04:56
Hopefully all it needs for engine work is a carb rebuild or something very simple, that would be pretty sweet, but if it needs more than that he can factor in about $500 for pistons, rings and sleeves, gaskets, then its additional money for bearings and a head rebuild if it needs it. That fellow has got $600 in the rear tires, not $1,200 unless the rims are brand new too. So it is a bargain if you consider what you are getting, but also be prepaired to throw a bunch more money at it before its all fixed up.
Vito
11-10-2007 08:53:32
Lanse,
I am with Walt.Please check this out.I should buy it just for the rear tires.
Vito
Walt Davies
11-10-2007 08:19:56
Lance if I were you I would seriously think about this tractor its got new tires on the rear that's $1200 dollars right there. Look clean an easy to put in like new condition.
Walt
PS maybe the guys on the list can help out some I could shake loose a few dollars if needed.
I wanna Farmall
11-10-2007 07:33:46
3 hours by tractor???
135 Fan
11-10-2007 10:47:37
 Re: Lanse! Lanse! Wake up! in reply to I wanna Farmall, 11-10-2007 07:33:46
You don't want to drive it home. Even you paid the guy a couple hundred bucks or so to deliver it would be reasonable. If its got some engine issues, check them out before you run it too much. The last thing you need is a stuck engine or something. Dave
M Nut
11-10-2007 07:53:38
Check the photo ads. Doesn't seem like to bad an old tractor to me for that price. Sounds like he may even help with delivery!
wilsonfire
11-10-2007 05:02:48
This could be THE ONE!
