Tractor Talk Discussion Forum
560 IH wide front factory
jmducks
11-13-2007 16:44:06
What other IH tractor does a 560 fact wide front fit?
notadeere
11-13-2007 17:32:28
 Re: 560 IH wide front factory in reply to jmducks, 11-13-2007 16:44:06
also should fit the H & M m for sure as IH is like Chevrolet interchangeable on lots of things if u got a ford u just as well go buy new...
Jim J
11-14-2007 15:27:01
 Re: 560 IH wide front factory in reply to notadeere, 11-13-2007 17:32:28
The 560 front will fit a M if you change the rear mount. The steering arm and rear mount are different on a H.The front mount is the same from an H to a 1256.
IaGary
11-13-2007 17:42:45
A little modifying has to be done to fit the H and M.
The 4 mounting hole at the front are a different height than the 560.
Gary
jmducks
11-14-2007 15:17:55
 Re: 560 IH wide front factory in reply to IaGary, 11-13-2007 17:42:45
Does it fit 656,706,806,856? and more
K.B.-826
11-13-2007 16:58:14
460, 706, 806, 1206, 756, 826, 856, 1026, 1256, 1456, 544, 656, 666, 686, Hydro 70, Hydro 86.
