Tractor Talk Discussion Forum
Tire question
The Pennsylvani
11-17-2007 08:49:54
There is a set of brand new rear tractor tires that I'm looking at. They have been stored in a barn for about 5 years now and I was wondering what effect high and low temperatures would have on them. Theres only dust on them and they have been kept out of any sunlight.
iowa_tire_guy
11-18-2007 16:23:38
 Re: Tire question in reply to The Pennsylvanian, 11-17-2007 08:49:54
Sun is the only thing that hurts tires. Ever notice the snowbirds with covers over their camper tires.
shannon from ohio
11-18-2007 14:16:50
Get them and use them if stored inside. May be a little stiff but as long they were'nt in the sunlight (Weathercracks) they will be ok..... ....
LenND
11-17-2007 14:28:10
If they were new tires and the price is reasonable grab them. They are in better condotion than if they were on a tractor sitting outside for five years.
The Pennsylvanian
11-17-2007 18:23:02
 Re: Tire question in reply to LenND, 11-17-2007 14:28:10
well, these tires still have a distinct rubber smell to them and being 23.1 x 26 I think I will. Thanks for the replys.
MF Poor
11-17-2007 13:23:03
The question reminds me of when I helped my aunt and uncle shingle their house a few years ago. The lumber yard unloaded the shingles in their driveway while they were at the store. My aunt called and asked if it would hurt the shingles to leave 'em outside and get 'em rained on?
As was mentioned, direct sunlight has WAY more effect than heat/cold cycles.
in-too-deep
11-17-2007 14:39:57
 Re: Tire question in reply to MF Poor, 11-17-2007 13:23:03
Haha. Might want to send that shingle question to Bill Engvall...here's your sign. (No offense meant to the aunt and uncle, great laugh though :)
pair-a-dice farm
11-17-2007 11:21:52
Personally I would rather have them than tires that were right from the factory. They probably will be a little harder to mount but they will be more resistant to punctures
Dick L
11-17-2007 09:45:09
go over to the pulling board and ask. There will be guys over their that would fight you for them.
If I was still pulling I would be trying to beat you to them.
Gerald J.
11-17-2007 09:16:15
I've seen stored tractor rear tires that have turned stiff and would be hard to mount because of that stiffness. I knew they had been around a while because they were Armstrong tires and I saw them several years after that brand was renamed Titan.
I'm having good results with some Armstrong 6 ply on my MF-135 but many report early sidewall breaks.
Gerald J.
MF Poor
11-17-2007 13:54:09
 Re: Tire question in reply to Gerald J., 11-17-2007 09:16:15
I just replaced a set of 24 year old Armstrongs with a new set of Titans. They looked 24 years old, but if they had any tread left, I do believe they could have gone another 24. No sidewall failures to report.
Red Dave
11-17-2007 09:00:47
Just my opinion, but high & low temperatures would be less of a concern to me than would exposure to sunlight.
I would inspect them carefully and if they look good, they probably are good.
noncompos
11-17-2007 08:58:38
Hey. C"mon...give the tire guys a break, like: how cold was cold???(Frostbite Falls, MN, or Tucson??)...how hot was hot?? (Bangor, WA or Phoenix, AZ??)...what"s the brand name and any designations on sidewalls (some tires aren"t very good to begin with; others wear like iron)...exposures to any strong chemicals (hebicides, pesticides piled around tires??...stuff like that...post a little more info..(with sympathy)...
The Pennsylvanian
11-17-2007 10:48:33
 Re: Tire question in reply to noncompos, 11-17-2007 08:58:38
Pennsylvania conditions, that being 95 degrees to minus 10. Thay are BF Goodrich Bias tires. Thanks.
Joe (Wa)
11-17-2007 10:46:01
Yup, not enough info. Considering the "Pennsylvanian" handle there is no telling where this poster is from. Maybe Hawaii?
Joe
