Tractor Talk Discussion Forum
bulb chart
MPK
11-19-2007 20:18:21
Does anyone have a chart that shows 12v light bulbs for the old tractors that also shows the wattage of the bulbs. I am looking for some like 1141, 1143, 1156, 47, 57,and similar ones. Also substitutions, if possible. Also 6v, if possible. Thanks
buickanddeere
11-20-2007 10:16:59
 Re: bulb chart in reply to MPK, 11-19-2007 20:18:21
It's posted here if you search. I mostly got blasted for the idea of larger lamps if or where the charging system would be capable of handling the load. There are some very high lumen output LED lamp replacements that make the original incandescents look dim. Yet current draw is less than the original incandescent lamps.
Joe (Wa)
11-19-2007 22:25:44
Didn't spot the 57, but the others you listed are on this chart.
Joe
noncompos
11-19-2007 21:41:24
FWIW, awile back I ran across a site that (as I recall) advertised that it had obsolete bulbs, and my note says it has an online bulb index. If you don"t find your info you might try donsbulbs.com. Good luck.
Bob
11-19-2007 20:32:26
The link below is a bit "clunky", but will give you design Volts and Amps data by bulb number.
A helpful local auto parts store may have a GE or Sylvania catalog you could look at... the paper verisons are easier to navigate.
Link
