Tractor Talk Discussion Forum
Ford 600
Bubba in Al.
11-20-2007 12:16:12
Where is serial no. located on Ford 600? I have looked everywhere. Thanks Bubba in Al.
old
11-20-2007 15:46:33
 Re: Ford 600 in reply to Bubba in Al., 11-20-2007 12:16:12
Heres the easy way to find where it is. Take your left hand and put it on the starter. Then look just under the battery and you should see a flat spot right in front of your eyes. The number is stamped right there and will sort of look like this, say you have a 4 speed tranny. 640
XCVBN
If you have a 5 speed it will be
650 or 660
XCVBN
Bubba in Al.
11-21-2007 06:35:12
 Re: Ford 600 in reply to old, 11-20-2007 15:46:33
Thanks Old, Went right to serial no. on Ford 600.
Newer than thought, 1957. Thanks to all. Bubba in Alabama
aLAN bane
11-20-2007 13:29:57
THEY USED A NUMBER PUNCH TO PUT THE NUMBERS ON WITH
Ken Crisman
11-20-2007 12:28:40
Bubba , you will find the numbers stamped on that flat area of the bellhousing just under the oil cup of your aircleaner . Hopefully nobody used a grinder when stripping paint . The best way to is to use a little paint stripper . Please don't use harsh sqandpaper or ya might remove the stamping . Once I found mine (it was hard also) I took a very small chisel & carefully stamped all numbers deeper so new paint didn't cover it up . If ya still have troubles look at John Smith website . My email is callj.j.s@verizon.net . God bless, Ken
MIKE FRENCH
11-20-2007 12:22:45
Its on the left side stamped in the flat place on the clutch housing, there is no tag
