Tractor Talk Discussion Forum
SERIAL NO. FOR 801 FORD
John-John
11-23-2007 16:21:21
Where would I find the serial no. of my 801 Ford tractor? I found two numbers under the seat mount which are NOA501 on top, with -B- below then 1H24 on third line. If these numbers relate to the serial or ID no. then please explain if possible. If not tell me where/ what to look for.
I am new owner so any help from you experts would be greatly appreciated.
old
11-23-2007 17:24:18
 Re: SERIAL NO. FOR 801 FORD in reply to John-John, 11-23-2007 16:21:21
Hers the easy way to find the numbers you want. Take your left hand and put it on the starter and your right hand on the clutch pedal>. Just under the battery box you will see a flat spot there. That is where the numbers your looking for are. They should look sort of like this.
841
XCVBN if it has a 4 speed tranny or 850 or 860 XCVBN if it has a 5 speed tranny
