Tractor Talk Discussion Forum
Little By Ever-lovin' Little
Allan In NE
11-25-2007 14:54:46
'Taint much,
But, I did get that broken door glass fixed today. That has been botherin' me like crazy!
Question: The idler pulley for the hydro. Can't see any keepers of any sort. Does that bearing assembly just press out of the hub?
Don't tell me they're gonna make me buy the whole pulley? :>(
Allan
third party image
third party image
Tradititonal Farmer
11-25-2007 22:57:28
 Re: Little By Ever-lovin' Little in reply to Allan In NE, 11-25-2007 14:54:46
If you are really lucky the guy that bought the parts F new that you have will show up wanting it(LOL)
37 chief
11-25-2007 19:20:39
Allan I hope you don't run across one of your old girl friends from the 80's and bring her home. Just kidding I know you are smarter than thet. Now to the bearing If there is no snap ring, it may just be a press fit. As someone previous, said heat it up and it should press out. Looks like you are having fun. stan
Spook
11-25-2007 16:50:37
I don't know much about combines, but that pulley has been balanced, it is going to be expensive to replace, methinks. I really enjoy your projects!!
westtexas
11-25-2007 16:13:20
I hope all this spending helps your heart and head problem(both time and money) Your going to show those mean bankers, right.
37 chief
11-25-2007 22:23:52
 Re: Little By Ever-lovin' Little in reply to westtexas, 11-25-2007 16:13:20
What do you have shorts all waded up about. The guy is getting a piece of the past up and running again. All I do is work on old stuff, and really enjoy it. Have a drink and go to bed. Stan
Allan In NE
11-25-2007 18:24:29
And now you're using the handle "westtexas"?
Allan
LilFarmer
11-25-2007 15:38:56
Allen,
If I remember correctly, (gittin' harder & harder) there is a spiral ring holding that bearing. Same as a snap ring only thinner and wraps around about two or three times. Should be a notch in the outside end that you can get a screwdriver behind and work it outa there. Also, I think the pivot end of that arm can be bored to a bigger size and you can sleeve the pin to accomodate the larger bushing. Drill and tap the end of the pivot pin for a 1/2" capscrew and use a capscrew and heavy washer to hold it together.
I could be all wet, too!
Allan In NE
11-25-2007 18:32:36
 Re: Little By Ever-lovin' Little in reply to LilFarmer, 11-25-2007 15:38:56
Hey!
That would work. Thanks!
Allan
Janicholson
11-25-2007 15:14:09
Wire brush th bejebers out of the bore, Look at it with a hand lense to see the rounded edge of the bearing outer edge on the bore, warm up the hub to cant touch it temp with a propane torch, and press it out. JimN
Allan In NE
11-25-2007 15:21:42
 Re: Little By Ever-lovin' Little in reply to Janicholson, 11-25-2007 15:14:09
Okay,
I can see a tiny little, looks like a "tin lip" around the very edge of the bearing. Doesn't look like any kind of a "keeper" that I'm aware of tho.
I'll talk to parts first and see if they have just the bearing or how they usually handle it.
Allan
in-too-deep
11-25-2007 15:12:14
The way I see it, if it was pressed in, it can be pressed back out. Better start soaking in your favorite penetrant. If a Gleaner bearing isn't available I'm sure we can find you one that'll fit.
Allan In NE
11-25-2007 15:17:21
 Re: Little By Ever-lovin' Little in reply to in-too-deep, 11-25-2007 15:12:14
Told my friend George who runs the parts department to start ordering F2 parts 'cause I was gonna need a truckload of 'em.
He says, "Chances are I've already got what you'll need". :>)
They are usually pretty darned reasonable on bearings. Kinda worried about those big mainshaft dudes tho. Those honkers are growlin' big time. :>(
Allan
in-too-deep
11-25-2007 16:30:42
 Re: Little By Ever-lovin' Little in reply to Allan In NE, 11-25-2007 15:17:21
Just need a little more penetrating oil and a little bigger press ; )
nhboyd
11-25-2007 15:04:23
I haven't done a lot of work on F2 to small for this area. I would bet it will press out. Some had a snapring to remove first. Can look in book tomorrow. Neil
Allan In NE
11-25-2007 15:12:37
 Re: Little By Ever-lovin' Little in reply to nhboyd, 11-25-2007 15:04:23
Went over and looked at the old F.
It is basically the same except it has a stamped/riveted pulley instead of the cast. No snap-rings 'er nothing on that one either.
I've got to do something about it's arm/pivot pin also. That thing was givin' me fits when I owned it before. Runs crooked on the pin and now of course, has wobbled out both the eye of the pivot arm and the darned pin as well.
Don't know how I'm gonna handle that one yet, 'cause that pin is welded into the back side of that big transmission mounting plate.
Oh well, one day at a time I guess. :>(
Allan
nhboyd
11-25-2007 23:48:24
 Re: Little By Ever-lovin' Little in reply to Allan In NE, 11-25-2007 15:12:37
you can grind the weld off that holds the pin and replace it with a shaft the right size. check to see what a new arm cost. you can have a eye made and weld on the old arm.
