Tractor Talk Discussion Forum
Block Heaters
Jwill
11-26-2007 05:44:12
I have a older model Case 1370. She's not the easiest one to get started on these cold days. It does not have a block heater and I was thinking about buying one of these "magnet block heaters". Does anyone have any thoughts on these? Do they work ?
DiyDave
11-26-2007 17:35:11
 Re: Block Heaters in reply to Jwill, 11-26-2007 05:44:12
The only thing the magnetic heaters are good for is defrosting a fuel filter, if it gels. Use a freeze plug heater if you can, or a tank heater, or a lower rad hose heater, all work better!
No tools
11-26-2007 09:44:44
It Just my 2 cent but you should have two plugs in the left side of the block.Go to CASE IH get the regular heaters for it requires 2 i think you will be lot more pleased.The are a stick type. Here is a old part number A 40476 cord A 40477 this number may be (sub) to new number.
sd pete
11-26-2007 08:24:37
I always liked frost plug heaters.
old
11-26-2007 07:38:03
If its any thing like my 930 it should have a manifold heater and if it works you should be able to get by with it. I know my 930 will start easy no matter how cold it is as long as it has a good hot battery and I use the manifold heater. Now if you still want to add a heat the only way to go is one the warms up the coolant because the ones that warm up the oil can burn the oil and they also don't warm up the whole engine but the coolant heaters warm up the whole engine
Jwill
11-26-2007 07:50:24
 Re: Block Heaters in reply to old, 11-26-2007 07:38:03
Are the 1370's supposed to have one of the manifold heaters on it?
old
11-26-2007 08:08:26
 Re: Block Heaters in reply to Jwill, 11-26-2007 07:50:24
Can't say yes or no to that but I would think if its diesel it would because my 930 has it and I would think they would have done what they did on the 930 to that one also
Steven f/AZ
11-26-2007 07:30:55
In my experience, the magnetic heaters do next to nothing.
Get a real block heater that goes in where a casting plug is, or get at least a 1500 watt tank heater.
Dachshund
11-26-2007 06:39:45
I've got one (don't know how many watts) that works just fine. As long as the tractor is out of the wind, it will heat up real nice.
old
11-26-2007 07:39:01
 Re: Block Heaters in reply to Dachshund, 11-26-2007 06:39:45
Hey G long time no see. Hows everything going
Dachshund
11-26-2007 08:00:11
 Re: Block Heaters in reply to old, 11-26-2007 07:39:01
Not too, bad, Old! Just been piddlin' around up here. Even had some snow last week. First day all year that the cats weren't on the front porch waiting to be fed. The wimps.....
old
11-26-2007 08:06:43
 Re: Block Heaters in reply to Dachshund, 11-26-2007 08:00:11
Sort of wish we would get a tad bit of snow. Sure would help with the deer hunting. They seem to hide well with out the snow. LOL
Dachshund
11-26-2007 08:12:39
 Re: Block Heaters in reply to old, 11-26-2007 08:06:43
Yeah, it's gone now. I don't mind snow and cold - it's the wind I hate!
skip33652
11-26-2007 06:20:58
If there is a place to put block heater do so. if not find the biggest tank heater you can find and put that on.a magnetic heater will not be big enough to do anything except waste electricity.
aLAN bane
11-26-2007 06:09:08
Bought one at Trractor Supply, thought it was a waste of money.
Dan-IA
11-26-2007 06:02:28
They work...yes.
But the one I bought was a meager 600 watts. It was the biggest one I could find too. So, unless you can get 'em bigger than mine, don't get in a hurry about it.
Bob - MI
11-26-2007 06:01:07
If you choose a heater make sure that you use the right size cord for it. Local road commission barn burned down a few years ago because the guys didn't use the right gauge extension cord.
steveormary
11-26-2007 09:02:34
 Re: Block Heaters in reply to Bob - MI, 11-26-2007 06:01:07
I was never impressed with the magnetic heaters. I used the external tank heater and found they worked very well.
steveormary
