Tractor Talk Discussion Forum
Allis Chalmers model
Johnny Tractor
11-27-2007 21:32:12
We are restoring an Allis Chalmers what we think is a "B" The serial number tag has the letter "C" before the numbers. This tractor hast he wide front on it. From the pictures I have looked at on this site the B's were all wide fronts and the C's were narrows. Am I correct?? Or does the C in front of the Serial number have no bearing? Thanks for any help to this young restorer!!
Matt L
12-03-2007 15:39:04
 Re: Allis Chalmers model in reply to Johnny Tractor, 11-27-2007 21:32:12
Depends on the year of the B earlier stuff was 116ci
CA was 125ci
BLW
12-03-2007 07:17:55
OK now we have a B crank job wide and a CA with a loader and hyd neither one looks just like these the CA is a much bigger tractor by the looks of it=- i am told they all used the same engine ??? we are selling them anyway don't have time to play with them anymore
Keith-OR
11-28-2007 10:37:54
 Allis B wide front end in reply to Johnny Tractor, 11-27-2007 21:32:12
Ok, now here is your Allis B with a wide front end, as you can see steering is different. Both arms face down, also it is a completely different type of WFE, more of a wish bone style.HTH
Keith & Shawn
third party image
Keith-OR
11-28-2007 09:43:59
 Allis C w/ WFE in reply to 37 chief, 11-27-2007 21:32:12
Here is picture of an Allis C with wide front end. As you will notice both the steering sector arm(pitman) and the arm on the front end face up and on the Allis B they face down. Also the C as an adjustable WFE.
Keith & Shawn
third party image
third party image
old
11-28-2007 09:25:53
Well that number says its a C but since it has the wide front what you have is a C with a B front end on it. Yep many parts from Cs and B will work on either one. The C is a little wider then the B in the rear and has a little more power then a B but for the most part they are the same tractor and use the same engine
