Tractor Talk Discussion Forum
OT Taking plugs wires off of spark plugs '03 Impala
Brad in WI
11-28-2007 15:37:01
How can a person remove the factory spark plug wires off of the plugs in a 2003 Chevy Impala. It has the 3.8L engine and some sort of metal heat sleeve? over the boots. I tried to twist it loose and pull them off but I cannot get them to move. Is a special tool needed to break the metal ring or am I just a wuss. any help is appreciated. Thanks
Brad
JoeK(WI)
11-28-2007 16:07:59
 Re: OT Taking plugs wires off of spark plugs '03 Impala in reply to Brad in WI, 11-28-2007 15:37:01
There is a pliers made just for sparkplug boots,as on modern engines they fit tightly and kinda glue themselves on.I believe theres also a dilectric grease to put in em,so it's easier the next time around.If yer not a tool snob :),the pliers outta be available in Lisle,KD or other general purpose lines."Spark Plug Boot Pliers"
Jon Hagen
11-28-2007 16:06:49
There is a special hook like metal tool to remove them. a cheap item at an auto parts store.
Those boots really bond to the plugs, even with the correct tool you sometimes destroy the wire while trying to remove it. Coat the inside of the boots with silicon grease(also from the auto parts store) to prevent their re sticking.
