Tractor Talk Discussion Forum
OT Dodge Cummins engine ID
John S-B
11-30-2007 13:47:39
I'm having a friend replace the injectors in my Dodge cummins. He needs some numbers from my engine but I've dicovered the data plate has come off for some reason. How do I find out the info as to the engine serial #, the dealer I called was no help. My Dodge was delivered in Oct. of '94, it was a 2500 club cab 4x4, one of the first of that body style made.
jdemaris
11-30-2007 14:16:33
 Re: OT Dodge Cummins engine ID in reply to John S-B, 11-30-2007 13:47:39
All you've got to do is get the numbers off one injector nozzle itself - you don't need the engine info. That can eliminate some confusion.
Generally speaking, there are two different injectors for that year - one for automatic trans R4761596 and one for five-speed-manual trans R4761595.
If you don't want the down-time of pulling injectors, getting numbers, and waiting for nozzles - just call a place like Oregon Fuel Injection. They will send you the complete injectors with new nozzles installed and ready to go into your engine - and you then send back your old ones. Cost around $50-$60 each. Phone # is 800-452-5055
I usually do them myself, and new nozzles cost anywhere from $5 each to $20 each.
(sonny)
11-30-2007 14:11:57
go to cummins ,they can tell you how to find the information you are looking for.dodge only installed the engine,if you need engine parts ,go to cummins, dodge ,dodge want have them. as per my experience, sonny
good luck
