Tractor Talk Discussion Forum
Massey 135/235 loader
Prairie
12-01-2007 07:55:28
I have a Massey 135 with loader and want to switch the loader to a 235. Looks like it should fit but wonder if anyone has the experience to verify. A photo of a 235 with loader attached would be a tremendous help. Thanks Prairie
135 Fan
12-01-2007 09:29:38
 Re: Massey 135/235 loader in reply to Prairie, 12-01-2007 07:55:28
There both very similar in size so it should switch right over. One question would be why? Is something wrong with the 135? 135's have a better reputation than the 235's. Don't get me wrong, the 235 is good tractor but they had some issues, mostly with the power steering. On the 245, they went to hydrostatic steering which solved the problems. Dave
335LP
12-01-2007 08:58:57
Try entering a google search ? For "MF 235 with loader image" and several will come up. Should work unless some mounting holes are different on front?
Gerald J.
12-01-2007 08:40:59
My MF-135 HAD a 236 loader. That was too much loader for the tractor. Its now on a JD 4020.
The best document you need is the loader manual. It will show you the brackets needed to fit the loader to the tractor AND the procedure for mounting and removing the loader.
After years with a PTO pump, I went to a pump driven off the engine crankshaft so I didn't have to remove the loader to run a mower or baler.
Gerald J.
