Tractor Talk Discussion Forum
IH 300 utility
Dan Cook
12-01-2007 17:50:04
I"m told there is really nothing to go bad in a hyd. pump on my 300 utility. I have what seems to be a pump problem. The 2 point hitch will go up and down at half thottle or better.If I stand on the 2 point hitch it doesn"t have enough power to pick me up.I have tryed 3 different valve regulator boxes on it and there"s no difference. At an idle the 2 point hitch won"t move at all. Thanks for any feed back, Dan
MARK R
12-02-2007 18:22:39
 Re: IH 300 utility in reply to Dan Cook, 12-01-2007 17:50:04
I WOULD CHECK THE SCREEN UNDER THE RESEVOIR TOP.THE TOP IS HEAVY TO LIFT OFF AND TAKES 2 PEOPLE TO LIFT.THE RESEVOIR IS UNDER YOUR SEAT.THE SCREEN CAN BECOME RESTRICTED,AND STARVE THE PUMP.
old
12-01-2007 21:31:10
Common problem with the Farmalls/IH tractors. Hyd pumps wear and then you have little/no pressure. Only fix is a new pump. Yes they can be rebuilt but the common man doesn't have the stuff to do so and even if you could get the parts it will not work unless you have all the tools to do the job and they cost $10,000 plus
rrlund
12-02-2007 08:12:20
 Re: IH 300 utility in reply to old, 12-01-2007 21:31:10
Did you get one zero too many in there old?
old
12-02-2007 08:27:28
 Re: IH 300 utility in reply to rrlund, 12-02-2007 08:12:20
Nope, you need some real high priced stuff to rebuild them pumps
in-too-deep
12-01-2007 20:48:42
Seals in the lift cylinders?
georgeky
12-01-2007 17:57:19
Well Dan, you have likely been told wrong. I suspect your pump is shot. There is no real rebuild for them. Seals and gaskets can be replaced, but gears sets are not available as far as I know.
