Tractor Talk Discussion Forum
Massey Ferguson 98 Serial Numbers
TERRY HANLON
12-02-2007 17:47:33
Having trouble finding a site which will give information on Massey Ferguson 98 serial numbers,I've tried YT'S tractor,Tractor data.com
Tractor Shed, with no luck. Any suggestions.
3-71 Fan
12-03-2007 12:08:36
 Re: Massey Ferguson 98 Serial Numbers in reply to TERRY HANLON, 12-02-2007 17:47:33
The Oliver fan is correct. The Massey 98 serial numbers are mixed in with the Oliver 990, 950 and 995 serial numbers. Massey did not give them a unique serial number. The trick is you have to drop the last three numbers to get your serial numbers. The last three numbers are a spec number that describe something like your gear ratio. Usually -942, -943 or -950. With the exception of a few in 1959 almost all the Massey 98s are 1960. Since the Massey 98 is 99.8% an Oliver 990 by weight you will probably have the best luck asking questions about it on the Oliver board. How long have you had it?
oliver fan
12-02-2007 18:09:02
Look up Oliver serial numbers, then click on model 990. That model of tractor was built for Massey by the Oliver corp. and carry Oliver serial numbers.
TERRY HANLON
12-02-2007 18:53:47
 Re: Massey Ferguson 98 Serial Numbers in reply to oliver fan, 12-02-2007 18:09:02
I'VE CHECKED THE 990 SERIAL NO'S AND THEY RANGE FROM 53001 IN 1958 TO 115469 IN 1961,THE MF98 ARE IN A DIFFERENT FORMAT, EXAMPLE AS FOLLOWS 86-952-942. I'M ASSUMING MASSEY FERGUSON HAD TO HAVE THIER OWN SERIAL NUMBERS, DIFFERENT FROM OLIVER'S
Terry
oliver fan
12-02-2007 19:10:50
 Re: Massey Ferguson 98 Serial Numbers in reply to TERRY HANLON, 12-02-2007 18:53:47
The first Oliver 990's were built in South Bend, IN. in 1958. Then production was moved to Charles City, IA. for 1959 and there after.
All Massey Ferguson 98's were built in Charles City, IA. in 1959 and 1960. Your tractor serial number 86-952 was built in 1960.
TERRY HANLON
12-02-2007 21:14:44
 Re: Massey Ferguson 98 Serial Numbers in reply to oliver fan, 12-02-2007 19:10:50
I REALLY APPRECIATE THE INFORMATION ON THE 98, CAN YOU REFER ME TO A SITE THAT HAS ANY OF THIS INFO POSTED ON IT.DO YOU KNOW IF SERIAL NO 86-4764-948 IS A VALID NUMBER AND IF SO WHAT YEAR THAT ONE IS?
THANKS
