Tractor Talk Discussion Forum
Bought a 3000, Model shows its a 2000.
73driver
12-02-2007 20:15:14
Bought a Ford 3000 with a loader only to find out tonight from the model # that it is a 2000. Curiously, the hood has 3000 decals and yet the Identification Plate under the hood matches all the numbers on the tractor itself. I guess someone either put a different hood on it and moved the ID Plate or different Decals. I probably paid too much for my 3000...oops I mean 2000.
Jon
02
12-02-2007 21:01:55
 Re: Bought a 3000, Model shows its a 2000. in reply to 73driver, 12-02-2007 20:15:14
I bought a 2000 identified by hood decal only.No serial tag. I thought maybe it's a 3000 'cause that 3 cyl gas has lot's of power!
IanC
12-06-2007 08:35:54
 Re: Bought a 3000, Model shows its a 2000. in reply to 02, 12-02-2007 21:01:55
The ID numbers are STAMPED into the bell housing on a flat pad aproximatly over the starter nose cone. There will be three lines of information. With these you can fully identify your machine.
mowr
12-03-2007 08:15:24
You can tell which engine it has by checking the engine serial number. There is a horizontal machined pad on the bottom rail of the block, right side (starter side), just above the oil pan, with a serial no. stamped in. There you should see a letter followed by numbers: the letter B=2000 series, C=3000, D=4000.
02
12-03-2007 10:03:06
 Re: Bought a 3000, Model shows its a 2000. in reply to mowr, 12-03-2007 08:15:24
Thanks,I'll do that and let you know.
