Tractor Talk Discussion Forum
1952 Ferguson Hydraulics
Gene Reichard
12-03-2007 06:09:47
Hello All: I Rebuilt Hydraulic Pump, Replaced piston & Rings. Got Rebuild Package With All Moving Parts Seals Gaskets Etc.After Cleaning Installing All Pcs.Checking,Taking TIME Watched Vidio On How To Rebuild Hyd.I Must Have Missed Something. Lift Arms Would Not Lift At First Then Started Moving Up Slow Got A Little Faster But Real Slow With Some Chatter or Vibration, I Can Lift Round Bale But Will Sag Down After Time.Have Any Ideas?
El Toro
12-03-2007 07:30:55
 Re: 1952 Ferguson Hydraulics in reply to Gene Reichard, 12-03-2007 06:09:47
You may not have all the air bled from the system. Hal
Gene Reichard
12-03-2007 08:46:02
 Re: 1952 Ferguson Hydraulics in reply to El Toro, 12-03-2007 07:30:55
Do you Know How To Bleed Air Out? Hope That Is The Prob.
El Toro
12-03-2007 09:24:40
 Re: 1952 Ferguson Hydraulics in reply to Gene Reichard, 12-03-2007 08:46:02
You should place this request on the MH & MF forum. They have probably had this problem before. You probably need to keep working the hydraulic control levers. Keep a close watch on the fluid level too. Hal
Gene Reichard
12-03-2007 09:42:14
 Re: 1952 Ferguson Hydraulics in reply to El Toro, 12-03-2007 09:24:40
I Will Do That Thanks
soundguy
12-03-2007 12:43:31
 Re: 1952 Ferguson Hydraulics in reply to Gene Reichard, 12-03-2007 09:42:14
The first slow / bumpiness may have bene it bleeding.
The leak off can be relief valve, or bad cyl. I know you repalce dthe piston and rings.. but if the cyl bore is worn wide.. you will leak there..
soundguy
Gene Reichard
12-03-2007 13:36:53
 Re: 1952 Ferguson Hydraulics in reply to soundguy, 12-03-2007 12:43:31
I Think They Sent Junk rings Didn't Fit Right.Do Ya Know If 1952 Ferg. Will Take Same oil As 9n Same Year? That Is What I Put In. Sounds Like It Will Bleed Out By Useing It. Thanks For Taking Time To Answer
soundguy
12-03-2007 14:12:24
 Re: 1952 Ferguson Hydraulics in reply to Gene Reichard, 12-03-2007 13:36:53
9n stopped production in 1941.. however 8n went till 52.
The hyd system between a 9n and 8n is very similar.. and the hyd system betweent he 9n/2n and the fergy belly pumps are similar.. at least ont he t* 20 series.
If your pump is the belly pump and it takes a heavy mineral oil.. then yes.. the 90wt oil at tractor supply marked for use with ford from 1939-1952 should work.
if the rings were not right and the cyl was not repalced.. you very well could ahve a significant hyd leak at the mouth of the cyl.
Soundguy
