Tractor Talk Discussion Forum
how to get rid of ice in gear oil when stuck/won't move ?
jim in ny
12-03-2007 16:25:40
any of you gents got any tricks to can rid the water -- turned to ice -- that is in gear oil and has caused my rig to be frozen/won't move ?
Need to somehow get it out and put in new gear oil and seal the trans boot... JIM
maplehillfrm,pat
12-04-2007 07:19:35
 Re: how to get rid of ice in gear oil when stuck/won't move in reply to jim in ny, 12-03-2007 16:25:40
I have had to do that on a tractor before, I dragged it ti the barn, put the salamander to the back, put a piece of sheet metal by the front to deflect the heta back ,, a few hours later it was good to go,, to change the fluid,, I would see see why the coals wouldnt work either but never did that route,, good luck,,, pat ,,,
also from ny by norwich, played in the snow with my 250 with the plow on it,, my days of back blading are done,, nice and warm, with teh radio playing ,,,,
rrlund
12-04-2007 06:06:11
My Oliver 70 did that a few years ago. Sat in front of the feed grinder,went to move it and it wouldn't go. I skidded it in to the shop,pulled the drain plug and sat the salamander behind it for a few hours.
Don-Wi
12-04-2007 00:29:59
We use a magnetic heater on the transmission of our 165 in the winter to warm up the hydraulic oil- it's a common reservoir w/ the loader and it's really slow til it warms up. Then it's just slowish.
Donovan from Wisconsin
cole in mo.
12-03-2007 17:48:54
On a jd 60 at 15 below froze solid I slid a 5 gallon metal bucket about 1/2 full of charcoal brickets under it, thawed it out enough to get it loaded.
`Bernie in MA
12-03-2007 17:25:04
To help get the 2N Ford started I've put the live coals from the woodstove in a shallow bucket and put'em under the oil pan with a blanket over the hood. Didn't own a salamander then.
BigMarv1085
12-03-2007 17:24:44
What about one of those dipstick heaters? or maybe even drain some of the fluid out and heating it in a boiler then putting it back in. That should get you rolling until you can change the fluid and get all of the water out.
ScottyHOMEy
12-03-2007 16:48:59
I've used Bernie's method from down below with success.
bradk
12-03-2007 16:42:51
Contractor's propane heater or Knipco kerosene heater aimed at the rear trans/diff.Try to enclose the area with plywood and canvass tarps. ~brad
steve from mo - dangit!
12-03-2007 16:39:58
Alcohol - like Heet or an off-brand.
Puddin Tane
12-03-2007 16:30:47
A small BBQ lit, and placed underneath?
504-2
12-03-2007 18:35:18
 Re: how to get rid of ice in gear oil when stuck/won't move in reply to Puddin Tane, 12-03-2007 16:30:47
I have used the hog pan and charcoal method with a blue tarp over it, works fine.
steveormary
12-03-2007 20:22:25
 Re: how to get rid of ice in gear oil when stuck/won't move in reply to 504-2, 12-03-2007 18:35:18
Usea a knipco heater aimed at the differential and oil tank for loader and plugged in a lower radiator hose heater for the tractor engine. Worked good.
steveormary
