Tractor Talk Discussion Forum
Waht's A Boxblade?
Glenn F.
12-05-2007 13:55:09
Is it just a mounted blade with end caps on it...? Please inform.
Thanks,
GlennF.
Walt Davies
12-05-2007 20:49:26
 Re: Waht's A Boxblade? in reply to Glenn F., 12-05-2007 13:55:09
Mine has a tumble setup so you can change from blading to ripping to back blading without ever getting off the tractor.
Walt
PS I go take a pic but its dark out there.
J.C.in AZ.
12-05-2007 14:07:06
Most Box Blades I know of have a leading edge Bar which the Hitch and Side wings are attached to and which can be used as a Tool Bar for attaching Ripping Teeth into.The blade part is also part of this assembly.Where I come from the tool is always refered to as a "Box Blade with Scarifier Teeth". When I moved to Az. I hear it refered to as a "Gannon" . I found Gannon is the name of a Mfg. of Box Blades so I will still call it a Box Blade no matter what these People here in Az. call it[most every one here is from some where else,so go figure}
ScottyHOMEy
12-05-2007 14:16:47
 Re: Waht's A Boxblade? in reply to J.C.in AZ., 12-05-2007 14:07:06
Fella the other day asked why my back blade said "Bush Hog" on it. I allowed as how Bush Hog made it.
He didn't know it was a brand name.
Here
12-05-2007 14:00:27
third party image
Better Pic
12-05-2007 14:02:17
 Re: Waht's A Boxblade? in reply to Here, 12-05-2007 14:00:27
third party image
Stinky Cheese
12-05-2007 14:48:35
 Re: Waht's A Boxblade? in reply to Better Pic, 12-05-2007 14:02:17
I had to look real close... I thought that was a model S E X 720. Still I don"t see many times that they would be a good as a rear blade that tilt and tip and pivot and all that.
Tanklord
12-06-2007 11:24:17
 Re: Waht's A Boxblade? in reply to Stinky Cheese, 12-05-2007 14:48:35
You ought to see what happens to rear tires when a top link breaks and those scarifiers come forward...$900 later, 2 new tires!
Jim Johnson
12-05-2007 23:17:40
Well they are not comparable. Each has it's own job. A box blade is for leveling mostly.
J.C.in AZ.
12-05-2007 14:24:31
"Now you're talking" that is definately a "Box Blade with Scarifier Teeth" as I was taught to call it.
