Tractor Talk Discussion Forum
Another bad day at the Xmass tree farm.
Walt Davies
12-06-2007 12:51:16
So we got the little Case 485 stuck well we always have the IH 1066 but it hasn't run since last season.
Victor and I try jumping it with as many batteries as we have jumpers for to no avail she just won't crank fast enough or long enough to start.
So I pull the starter take it home and tear it down (I always say do it right the first time to save time and money). The commutator is black, I mean black burnt and copper melted . Can I clean it up without turning it. I get my Emory cloth out and a file to hit the high spots and go to work, it comes out looking pretty good so Victor puts it back in the next morning an it fires right up. Good for now.
They hook on to the little case and pull it free. Wait something else goes wrong the IH 1066 is buried up to is a$$ hole in mud and won't move. Now I have to take Ol' faithful (Case LA) out to the farm and try to pull it out.
As I said things were not going that good until we loaded that truck with 800 trees in 3 hours a record for us.
Walt PS now how do I get rid of that darn crotch itch BUMMER.
Bill46
12-07-2007 04:50:53
 Re: Another bad day at the Xmass tree farm. in reply to Walt Davies, 12-06-2007 12:51:16
Cortizone 10 in a small tube from walgreens...works like a champ and very cheap.
JMS/.MN
12-06-2007 22:56:20
Udder Balm.
37 chief
12-06-2007 17:45:59
You are lucky to have trees to load. Here in Calif during the last fire a large Christmas tree farm had almost all their trees burn up. Stan
Walt Davies
12-06-2007 22:58:06
 Re: Another bad day at the Xmass tree farm. in reply to 37 chief, 12-06-2007 17:45:59
Boy we ned to knock out a few more of them tree farms we got $4 a tree for the last load going to California and they get $50 to 4100 for them down there.
I heard that a 10 ft. Noble in SF will go for $350 we sell them for $20 and are lucky to get that.
Walt
I sell Douglas fir any size for $15 at my road side stand and some turkey stole two the other day.
Walt Davies
12-06-2007 22:56:58
Walt
I sell Douglas fir any size for $15 and some turkey stole two the other day.
Pat-CT
12-06-2007 17:04:32
you whant to hear about a bad day one christmas tree farmer woke up one morning to find teenagers had gone into his farm that night and cut the tops off 800 trees..what jerks
sheeptick
12-06-2007 16:48:49
I always thought, that was one of lifes greater pleasures for an old guy, was to set around and scratch his crotch, and you are trying to cure it lol.
BillinCentralMO
12-06-2007 16:03:29
It's called Lamasil . Can get it at the drugstore and it will clear up right away.
Goose
12-06-2007 14:05:55
Reminds me of when I was in high school. I worked for one of the neighbors for a couple of summers because my dad had things under control.
We had some heavy rains and some land got flooded. (The neighbor's). Before the flood, I'd been plowing with a pull type plow on some of the land that got flooded. While we were waiting for things to dry out, I was out with a 44 Massey fixing fence one day, and on the way back I hooked onto the plow to pull it home. The plow was on rubber and rolled right off.
I then went back and hooked onto a drag harrow. The harrow was stuck in the mud, both back wheels on the Massey took about a turn and the Massey was down to its belly in the mud. The boss came out with a WD, but he was afraid to get too close for fear of burying the WD. We wound up getting the two biggest wreckers in the county, used one for an anchor and the other one hooked to it to winch the Massey out.
steve from mo - dangit!
12-06-2007 13:56:23
Athletes foot cream if you scratch it and it smells like athletes foot. Cortisone cream if it doesn"t.
cahess
12-06-2007 14:33:04
 Re: Another bad day at the Xmass tree farm. in reply to steve from mo - dangit!, 12-06-2007 13:56:23
Well will try to be diplomatic.Iwould taKE long hot shower an with soft brush brush all crud off you can-brush hard as you can stand it .Than throughly dry an spray cruex on -my preference due to it being dry shortly after put on.Others mentioned probably will work also.You might jump when you sprayas it burns a few seconds. Dryness an not having affected areas touch each other are important an so if you roll two sheats of bounty paper in roll shape an use one on eighter side (2ROLLS)of efected areas keeping affected areas seperated best you can while you sleep it will help .dRY AN SEPERATED IS KEY!!!!
cahess
12-06-2007 13:24:37
419-674-3289 iwill tell you how to fix bomber part
DaveS
12-06-2007 13:21:57
Use clorox....I promise it won't itch any more. /snicker on
sheeptick
12-06-2007 16:58:25
 Re: Another bad day at the Xmass tree farm. in reply to DaveS, 12-06-2007 13:21:57
I always thought that was one of lifes greatest pleasures for an old guy was to set around and scratch his crotch.And here you are trying to cure the pleasure.lol
otto stook
12-06-2007 20:08:58
 Re: Another bad day at the Xmass tree farm. in reply to sheeptick, 12-06-2007 16:58:25
note to self,,after buying a tree dont shake hands with him to seal the deal!!!!!
