Tractor Talk Discussion Forum
# 1 cylinder
Dan Thornton
12-06-2007 17:40:41
Hey, which cylinder is the # 1,the right or the left on a 2 cyl john deere
old
12-06-2007 18:36:17
 Re: # 1 cylinder in reply to Dan Thornton, 12-06-2007 17:40:41
Would you believe most of the time they refer to them as left and right not 1 and 2. Even the owners manual I have for my 1935 JD-B refers to them as left and right not 1 and 2
RayP(MI)
12-06-2007 18:15:52
Guess, ya got a 50/50 chance!
Tom43
12-06-2007 18:28:12
 Re: # 1 cylinder in reply to RayP(MI), 12-06-2007 18:15:52
The flywheel side is number 1
Ole Dawg
12-06-2007 19:43:19
 Re: # 1 cylinder in reply to Tom43, 12-06-2007 18:28:12
So, whats the timing---left-right or right-left???
old
12-06-2007 20:54:00
 Re: # 1 cylinder in reply to Ole Dawg, 12-06-2007 19:43:19
Left side fires first then the right side.
Ole Dawg
12-06-2007 22:43:23
 Re: # 1 cylinder in reply to old, 12-06-2007 20:54:00
I thought one side fired four or five times before the other side fired then visa versy.
old
12-06-2007 22:48:55
 Re: # 1 cylinder in reply to Ole Dawg, 12-06-2007 22:43:23
Nope left side fires then the right side. Then it spins 180 and fires on the left then right 180 etc etc
Bob
12-06-2007 23:53:19
 Old, you know better than that! in reply to old, 12-06-2007 22:48:55
A Johnny Popper fires the LH cylinder, then 180º of crankshaft rotation later, the RH cylinder fires.
Then, there is a delay of 540 crankshaft degrees before the LH cylinder fires again,and the sequence repeats. They are NOT an "even-fire" engine.
That is what gives 2-cylinder DEERES their unique exhaust sound.
Mike (WA)
12-07-2007 07:59:03
 Re: Old, you know better than that! in reply to Bob, 12-06-2007 23:53:19
Almost unique- Harley Davidson is the other one.
John T
12-07-2007 05:36:12
Thats correct n is also the reason on the older single barrell carbs why at slow no load idle if you kill the left cylinder plug she will almost die yet if you kill the right cylinder it dont make near as much difference in how she runs.
Im sure Rich knows that, if He's like me the fingers n old brain dont always work at the same speed lol
John T
old
12-07-2007 08:04:48
 Re: Old, you know better than that! in reply to John T, 12-07-2007 05:36:12
What can I say if knew the 180 was in there some place and the 540 but didn't remember how to fill in the gaps. Sort of hard to see how one is working when your out there rakig hay with it LOL
