Tractor Talk Discussion Forum
Removing spark plugs
Animal
12-08-2007 05:07:29
I was working on a 620 John Deere yesterday and had to remove the plugs, those 2 buggers took a half a day to get out! I worked and worked and sprayed kroil on them and worked some more. Do any of you have a better way? If so what is it.
Mike M
12-08-2007 17:07:46
 Re: Removing spark plugs in reply to Animal, 12-08-2007 05:07:29
Hard to believe you had trouble getting plugs out of a 2 cyl. ? I have torn some nasty rusted ones down and haven't encountered that yet.
Janicholson
12-08-2007 09:02:17
Permatex Molybdenum disulfide anti-seize is great. Aircraft mechanics have used mica based anti-seize as well. The heat transfer capacity is important, I would be sure the material I use was not a barrier. JimN
Larry D.
12-08-2007 08:30:17
Every Time I replace Spark Plugs, I put a little "Dab" of Silicone Grease on the Top of the Threads... Granted it will Disipate to some degree ,But it will leave a Film on the Threads, Never had a problem with Cast Iron heads Or aluminum... Larry KF4LKU
baler46
12-08-2007 07:16:57
Hi
Just wondering if a little anti-sieze on those plug before you put then back in would help any.Might have to be some that will take that kind of heat
Bill(Wis)
12-08-2007 05:47:02
Deep Creep works better than anything I've tried and I've tried a lot of stuff over the years.
DJD-Man
12-08-2007 05:30:48
If not taking out and cleaned up every now and then they sure can be a animal to get out. BTDT. Are you sure they are the right ones? Heat.
Animal
12-08-2007 06:01:16
 Re: Removing spark plugs in reply to DJD-Man, 12-08-2007 05:30:48
yes sir, they are the right ones, just had not been out for about 20 years.
Don-Wi
12-08-2007 16:40:18
 Re: Removing spark plugs in reply to Animal, 12-08-2007 06:01:16
Copper anti-seaze is made for higher temps. I use it on just about everything, espescially spark plugs and anything that gets hot, like exhaust manifolds and muffler clamps.
Donovan from Wisconsin
DJD-Man
12-08-2007 06:36:07
Now that would be a fight. Understandable. Lucky you didn't snap them or something else. Just have to cuss at it and go for a walk then come back to it. Patience and Pblaster.
