Tractor Talk Discussion Forum
White 2-85 block
mike from cny
12-08-2007 17:37:24
Working on a "78 White 2-85 with the perkins straight 6 diesel. One of the sleeves corroded through and antifreeze got into the cylinder, so it was torn down, and its sat for like 3 years. Machinest says its a press in dry sleeve that usually is bored out because their so tight. I figured it had wet sleeves. What do you guys think?
J Schwiebert
12-08-2007 17:43:59
 Re: White 2-85 block in reply to mike from cny, 12-08-2007 17:37:24
They are dry sleeve. Most modern Perkins are dry sleeve. Now what you may need to do is have that cylinder bored and a repair sleeve installed and then cut to fit the Perkins sleeves. They are tight.
rrlund
12-09-2007 08:06:38
 Re: White 2-85 block in reply to J Schwiebert, 12-08-2007 17:43:59
The instructions that come with those sleeves say to bore the block some miniscule amount,but I've frozen them and pressed them in.
