Tractor Talk Discussion Forum
Anyone know where the computor is in '95 Corsica ?
Jim in NY
12-09-2007 09:41:05
I have to change this for my daughter need to know where it is and approximate cost and time to change it ? Thanks gents.... JIm
El Toro
12-09-2007 16:19:21
 Re: Anyone know where the computor is in '95 Corsica ? in reply to Jim in NY, 12-09-2007 09:41:05
I had a Chevy Citation and it was in the glove comparment. Had to take it to a dealer. Hal
marlowe
12-09-2007 12:57:20
why do you think it's bad??
Jim in NY
12-09-2007 10:01:09
 Re: OT (forgot) Anyone know where the computor is in '95 Cor in reply to Jim in NY, 12-09-2007 09:41:05
Forgot to mention this ... sorry Gents
bradk
12-09-2007 11:08:05
 Re: OT (forgot) Anyone know where the computor is in '95 Cor in reply to Jim in NY, 12-09-2007 10:01:09
PCM is located at the RH side behind and below the glove box.
The replacement is a eeprom type meaning a service program will have to be downloaded or "flashed" into the installed unit before it will run.
The PCM is about 200 bucks,GM dealer to download software to vehicle around 100-150 bucks.There's actually nothing you can do yourself,because they need to request info from your old pcm.
Why do you need to replace unit?Hasen't been alot of problems with these.
Jim in NY
12-09-2007 17:35:08
 Re: OT (forgot) Anyone know where the computor is in '95 Cor in reply to bradk, 12-09-2007 11:08:05
I expect to change it because the mexhanic that diid the dianostic on it says the reson it runs so radically rich and powerless (only at times) was believed to be it was the fault. Would a used type replacement just plug in and be okay without any downloading ?
bradk
12-10-2007 07:09:44
 Re: OT (forgot) Anyone know where the computor is in '95 Cor in reply to Jim in NY, 12-09-2007 17:35:08
I'd get a second opinion.Doesn't sound like the pcm at all.Any codes or service eng light on?Which engine 2.2 or 3.1? Any more info would help narrow it down.~brad
