Tractor Talk Discussion Forum
serial # for a Farmall Super C?
Jim Beyer
12-09-2007 12:54:00
Can anyone explain this? On the serial # for a Super C it should start with FSC. I just purchased what I believed was a Super C, but it starts with FC. The confusing thing is the actual # is 181737 which makes it a 1953 Super C, I think.
gab
12-09-2007 18:10:18
 Re: serial # for a Farmall Super C? in reply to Jim Beyer, 12-09-2007 12:54:00
I think it's just FC. My 1953 is 173728, Jim
Jim Beyer
12-09-2007 19:21:11
 Re: serial # for a Farmall Super C? in reply to gab, 12-09-2007 18:10:18
Thanks for your reply.
gab
12-09-2007 18:10:07
Ray
12-09-2007 14:13:32
A super C has a water pump,a C doesn't.
Jim Beyer
12-09-2007 14:26:13
 Re: serial # for a Farmall Super C? in reply to Ray, 12-09-2007 14:13:32
Thanks Ray for the info.
Hugh MacKay
12-09-2007 13:38:47
Jim: You have a 1953 Super C, They all started with FC, however C serial numbers are all 5 digit or less, SC serial numbers are all 6 digit.
Jim Beyer
12-09-2007 14:24:02
 Re: serial # for a Farmall Super C? in reply to Hugh MacKay, 12-09-2007 13:38:47
Thanks Hugh for taking the time to reply
georgeky
12-09-2007 13:13:18
Jim, I should have put that SC has disc brakes and bent back pedals where the C has band brakes and straight pedals. SC gas tank will set about 2 inches above the hydraulic unit where as the C gas tank sits almost directly on the gas tank.
Jim Beyer
12-09-2007 14:25:26
 Re: serial # for a Farmall Super C? in reply to georgeky, 12-09-2007 13:13:18
Thanks for the info. and taking time to reply.
georgeky
12-09-2007 13:09:50
I have 3 Super C's and all of them start with FC, so does the 2 C's I have here. Never seen one with FSC on it before.
