This email was sent to the address below. I wanted to keep the others who contributed to this forum informed as well. I would be glad to send the photographs to others as well. It is the least I could do for the advise provided. Here are four photographs. They are the same quality, but I think they should enlarge nicely as they are from a high resolutino camera. yesterdays tractor limits the size of the photograph. If I thought it would be fairly inexpensive, I would rather fix the water pump; otherwise the elimination of it from the unit would be great. I have had the mag off about eight times. Also, I loosened or removed all of the bolts related to the pump. The main issue is how to remove the pump from the original magneto drive flange. There is a "slip flange between the drive flange and the pump and a vertial pin that is easily removed from the shaft that connects the two components. But I am not sure where to apply force to disconnect the two. If you would like additonal photographs I would be glad to take them, that would be the least I could do for your gift of advise. Any suggestions would be appreciated
