Tractor Talk Discussion Forum
O/T windshield wipers update
135 Fan
12-15-2007 18:15:07
I loosened the nuts on my wipers and turned them up and retightened the nut. They now work again, sort of. They work fine only on high speed but I can shut them off anywhere I want and they stay there. I'm thinking either the switch is buggered or there is a resistor that's bad, which stops low speed from working. Anyone had this problem before? 2000 Chev. 2500 Silverado. Dave
dave guest
12-16-2007 16:40:48
 Re: O/T windshield wipers update in reply to 135 Fan, 12-15-2007 18:15:07
There is a ground strap on them GM wiper motors. Make sure it is hooked around a screw or you will have all kind of strange things going on. Seems to me the wipers park because of a little limit switch in the motor. If linkage is set up wrong, then limit is never actuated and wipers won/t park.
Don Hopf
12-16-2007 13:20:20
Brothers Lumina APV van wiper motor did the same thing. I looked at the circuit board and found a couple of solder joints that were lose. I resolder the joints and it started working again.
Don Hopf
DaveS
12-16-2007 07:01:10
 Check for a RECALL in reply to 135 Fan, 12-15-2007 18:15:07
GM has had problems with their wiper motor boards for years and there have been recalls on MANY models about it. I'd call the dealership near you and ask.
Vern-MI
12-16-2007 05:09:35
You probably need this part...
onefarmer
12-15-2007 21:06:44
My 98 Jimmy acted like that. Intermittant, stop most anywhere, even stop when it wants too. Turned out there is a circuit board in the wiper motor. It was about $25-30 at the parts store. GM wanted over $120. Easy to change just unhook the connector, remove three screws, remove board and replace. Works great now.
Maybe yours is the same way? Hope so
135 Fan
12-15-2007 22:29:58
 Re: O/T windshield wipers update in reply to onefarmer, 12-15-2007 21:06:44
I'll look into that circuit board. The motor works fine on high speed so I doubt it's bad. Most 12 volt motors for heater fans and stuff use a resistor to slow them down. Dave
onefarmer
12-16-2007 07:37:47
 Re: O/T windshield wipers update in reply to 135 Fan, 12-15-2007 22:29:58
On mine it would work on highspeed, but on low it was intermittant and park was just plain worthless. On some wiper motors they use a second brush for two speeds, mostly because they want full power just at a lower speed. Don't know is these are this way. I did look up your outfit on partsamerica.com and didn't see the circuit board but the wiper motor was like $126.
kito169
12-15-2007 19:59:25
More than likely the motor needs to be replaced.
