Tractor Talk Discussion Forum
930 CASE WHEATLAND FRONT HUB CHANGE
BANDITFARMER
12-23-2007 12:28:34
LOOKING FOR 6 OR 8 LUG HUBS TO REPLACE 18"CENTER CAST HUBS FOR 930 CASE OR INFOMATION ON HUBS THAT WILL FIT ON IT
bradley martin
12-23-2007 15:47:57
 Re: 930 CASE WHEATLAND FRONT HUB CHANGE in reply to BANDITFARMER, 12-23-2007 12:28:34
The bearings and seals for the cast center wheels and the cast hubs w/ steel wheels are the same in the parts book, and only 1 spindle is shown, so I assume that the hubs will interchange. Find a set of hubs off a 930/1030.Both options were offered by Case.
BANDITFARMER
12-24-2007 13:25:58
 Re: 930 CASE WHEATLAND FRONT HUB CHANGE in reply to bradley martin, 12-23-2007 15:47:57
THANK YOU WILL LOOKING FOR SOME ASAP
Minn Norske
12-23-2007 14:38:08
Combine hubs are to small! I bought two hubs from Don Livingston (507-433-0073)This is in S.E. Minn.
Drill
12-23-2007 13:25:15
Look at the back(steering) wheels off an old combine. They usually use the same hubs and wheels.
BANDITFARMER
12-24-2007 13:23:35
 Re: 930 CASE WHEATLAND FRONT HUB CHANGE in reply to Drill, 12-23-2007 13:25:15
THANK YOU WILL START LOOKING ASAP
