Tractor Talk Discussion Forum
More tire info needed HELP
Larry59
12-26-2007 06:11:57
I recently found out I read my tire size wrong when posting it on here. The correct size is 16.9 x 28, also shows 4-28, and 15 " rim, firestone.
What does the 4-28 mean? The 15" rim throws me. That rim sure looks a lot bigger? I am going to buy soon two rear tires. But not sure what I am looking for with all these numbers.
Larry59
12-26-2007 13:18:03
 Re: Tires in reply to Larry59, 12-26-2007 06:11:57
Ok.. sorry about having some trouble understanding this stuff. But tires are really worn and by useing a Mag. Glass I see there is a 14-28 and not that 4-28. Thanks for the info everyone.
Joe (Wa)
12-26-2007 11:41:49
 Re: More tire info needed HELP in reply to Larry59, 12-26-2007 06:11:57
Go to the link & click on FAQ'S under MISCELLANEOUS.
Joe
Nebraska Cowman
12-26-2007 09:19:30
16.9 is the width measured at the widest part of the sidewall when mounted on a 15 inch rim. That same tire 50 years ago would have been called a 15 X 28 and would have been measured at the tread. I'd guess maybe the 4-28 number signifies 4 ply.
Larry59
12-26-2007 06:34:05
I just went back to an old post. See someone posted that the 15" is the width of the rim across. Not how tall it would stand up. Is this correct thinking?
mowr
12-26-2007 12:15:05
 Re: More tire info needed HELP in reply to Larry59, 12-26-2007 06:34:05
I believe rim-width is measured between the tire-bead-to-rim mating surfaces.
MN Scott
12-26-2007 06:46:16
Yup, your correct.
KEH
12-26-2007 06:39:51
Just get 16.9 x 28, 6 ply rating tires. Other numbers probably not important. 15 inches across sounds right for the wheel width.
KEH
