Tractor Talk Discussion Forum
chicken litter spreaders
maddog
12-26-2007 12:09:46
who makes the best one for spreading chicken litter, know of any good used ones out there.
Texasmark
12-27-2007 11:55:48
 Re: chicken litter spreaders in reply to maddog, 12-26-2007 12:09:46
I have cow poop and some non-eaten hay residue that I put on my fields.
I bought an old JD ****slinger for a few hundred at a local farm auction place. Had to replace a section of square chain and that was it. Local JD dealer had the chain. It has the moving floor scraper with the fingered wheels on the rear with an auger.
Maybe something like that would sling chicken poop too.
Mark
Leland
12-26-2007 21:54:37
To bad you can't find an old 2505 terra gator with the dry poop spreader bed those things are monsters ,the bed probley could hold 20 tons . an ag chem dealer may have one somewere .
Joe B.
12-26-2007 18:09:23
Chicken litter spreader for sale. Located in western KY. Will spread compost, decrust and litter. Am getting out of spreading. Asking
$3,500.00 for spreader. If not too far delivery possible.
sq
01-26-2008 13:16:21
 Re: chicken litter spreaders in reply to Joe B., 12-26-2007 18:09:23
still for sale
Dave from MN
12-26-2007 17:07:55
A knight slinger would work good. Contact your soil and water office. Alot of counties are purchasing them bigger verticle beater spreaders and you can dial in the rate you want. Most time you can use it for free if you spread it according to their recomendation and report the yeild difference to them.
pair-a-dice farm
12-26-2007 14:06:11
Most of the spreaders around here are Chandler or BBI some Adams. An all hydrolic is best. A converted comercial fertilizer spreader don't work very well because the door opening is too small.
JT
12-26-2007 13:30:10
look around for a used fertilizer spreader. If you get an old Henderson or Doyle spreader they have an adjustable door and the Doyle brand have a 2 speed gear box on the fans so you can change the rate as needed. There used to be a lot them around, everyone started going to the bigger trucks with floaters, so the small dry boxes were put back in the corner and not used. I do not know where you are, but my dad used to have 3 of the old dry spreader boxes, he sold one to a neighbor, one to a guy to spread chicken litter in Arkansas, I am not sure what happened to number 3, I will ask him tonight and see what happened to it. I am in central Illinois. You might be able to find one without a truck for a couple hundred dollars.
Jim
Ron in AR
12-26-2007 15:36:10
 Re: chicken litter spreaders in reply to JT, 12-26-2007 13:30:10
And that one in Arkansas is still spreading the $h!t. About 200 tons a year! And, it will be putting on lime this year too.
JonMN
12-26-2007 12:18:08
I have a Chandler litter spreader works good. A regular spreader will put it on to heavy.
