Tractor Talk Discussion Forum
JD 730 Diesel elec.st.
5020 iron
12-27-2007 10:49:03
Hi Im looking into buying a 730 anything that these are notorious for what do you think they are worth both high and low.enjoy your fires thanks(keep warm)!
James22
12-28-2007 12:35:39
 Re: JD 730 Diesel elec.st. in reply to 5020 iron, 12-27-2007 10:49:03
Yes, the flywheel can be a problem, be sure the nut stays tight. One of the gears driven by the crankshaft in the gear train driving the fuel pump/valve camshaft, I think it is an idler gear and would need get the book out to verify it exactly, is known to break the single mounting bolt and make a mess. Happened to mine before I bought it, and a friend's is now parked with the same problem. I've also read that the 1st gear reduction gear/bearing arrangement is not overdesigned and it can have problems.
rrlund
12-28-2007 06:55:52
Flywheel,flywheel,and flywheel. I put one used and one new on the one I had. I guess the taper lock flywheel fixes the problem.
John T
12-27-2007 11:35:49
Those 24 volt systems (if thats what it has) can be cornfusing for an experienced person let alone one electrically challenged lol. Ive owned 730 elec starter diesels n mine worked buttttt t it required maintenance n 4 good strong 6 volt batterys (or two twelves). Other expensive problems besides the complicated 24 volt electric start can be the flywheel and crank splines.
If she fires right up easy n the battery charges n stays charged n she dont knock or hammer or bang (bearings or rods or flywheel etc problems) or smoke or exhibit a lot of blow by it might actually still be a good tractor (I liked mine) buttttt ttt if not, it can cost a small fortune to repair.
Dont let us scare you however, best wishes n let us know how things turn out
John T
Tom43
12-27-2007 11:24:14
They are notorious for being worn out and costing tons of money to repair. A gas 730 would be so much cheaper and easier to repair.
RobMD
12-27-2007 17:14:46
 Re: JD 730 Diesel elec.st. in reply to Tom43, 12-27-2007 11:24:14
LOL
my wallet is light. oh well
Mike M
12-27-2007 11:53:28
I'LL SECOND THAT !
