Tractor Talk Discussion Forum
sediment bowl
tater
12-29-2007 19:52:16
I've got a 2 cylinder deere, that when I turn on the gas at the bowl, if the nut under the bowl is tight and sealing where the gas won't leak, I can't get enough gas to run the tractor. But if I loosen the bowl and let it leak the flow is better but still not enough gas. Now is there something I'm missing at the sediment bowl. I am stumped!!!!! !!!
greenmech
12-30-2007 19:46:45
 Re: sediment bowl in reply to tater, 12-29-2007 19:52:16
I believe there is a vent on top of the carb that will relieve pressure so the bowl will fill. Ron Mn.
rrlund
12-30-2007 09:05:46
What model is it? I had a 60 that had a shut off that worked from the oil pressure so it shut off when the tractor wasn't running to keep it from flooding if the float stuck.There's a thumb screw on top that you had to loosen,then push down on to let the gas in to the bowl and carburator. Another thing,not just on a Deere,but they all will fill a lot faster with the bowl loose than they will with it tight. What happens when you create a vacuum by trying to start it. Will it pull it in then?
tater
12-31-2007 14:34:30
 Re: sediment bowl in reply to rrlund, 12-30-2007 09:05:46
No, it will not flow better with a vacuum.
Allan In NE
12-30-2007 02:22:01
Try loosening your cap and see if the flow improves.
Allan
old
12-29-2007 20:32:26
Open/remove the drain from the bottom of the carb. Let it drain for at least 5 minutes. You need a good steady flow of gas there. Catch it of course. If you don't have a good steady flow then you have a clogged line or filter. Most of those old JDs have a screen in the carb and if its clogged you will have that problem. BTDT many times
