Tractor Talk Discussion Forum
1942 Case VA belt pully
tull
12-30-2007 13:42:15
Probably a simple answer but I don"t have it. How do I engage the drive for the mid mount belt pully?
Joe (Wa)
12-30-2007 17:43:09
 Re: 1942 Case VA belt pully in reply to tull, 12-30-2007 13:42:15
Here are some instructions w/pictures of what gene just said. This is a late manual, not everything applies to the older VA's but may help some.
Go to the link and click on last 2 pages to enlarge for reading at the bottom.
Joe
Gene Dotson
12-30-2007 14:46:53
Tull;
Yes, it is very simple. There is a pointed bolt with locknut on top of the housing. Loosen the locknut and back the screw out till the pulley can be pushed in to engage the drive gear. Be sure it is fully engaged, then retighten the lock bolt, being sure it engages the hole when you tighten it... Gene
