Tractor Talk Discussion Forum
Brake covers on farmall H tractor
Duane Bill
12-30-2007 16:02:25
I diconected all springs and bolts on covers and it seems to be held by the shaft that comes through the cover Is there a snap ring or something holding it around the shaft or what?
Clarkbug
12-30-2007 18:36:16
 Re: Brake covers on farmall H tractor in reply to Duane Bill, 12-30-2007 16:02:25
Are you talking about the covers themselves? Or the actuator piece that is mounted to the shaft? That actuator (for lack of a better word) is just slid onto that shaft, and there is a key in there.
Hit it with some kroil and then some gentle tapping, and they should pop right off.
Wayne in MN
12-30-2007 18:31:46
The shaft may be rusted into the opening in the transmission housing. Rotate the lever both directions and try spraying your favorite solvent behind the cover on the shaft & bushing area.
