Tractor Talk Discussion Forum
Building a firewood storage shed
RobMD
01-01-2008 08:57:13
Ok guys, so for the past 20 years my family has been stacking firewood around the non-running tractors and equipment in a closed shed.
I'm sick of tripping/climbing on stuff, so i'm looking to build a cheap wood shed with the wood I have around here.
My question is should the shed be open on all four sides or should it all be closed in for wood drying?
Mike (WA)
01-02-2008 10:22:53
 Re: Building a firewood storage shed in reply to RobMD, 01-01-2008 08:57:13
Slickest thing I've seen for wood storage was a chunk of big culvert- maybe 7 feet high- with wood stacked inside. Get a length appropriate to the amount of wood you are using. Can be damaged, etc. such that its unusable for culvert, but would work for this. Open on both ends, which is handy both for drying, and for access to drier wood out of one end while you put green wood in the other.
Garry in OK
01-01-2008 19:50:29
I have a small shed, 4 x 4 posts, gable roof with barn tin, reasonable overhang at the eaves, concrete floor, built tall enough I don't bang my head, no walls, holds about 3 cords.
I don't know if that"d work where you live, but it does fine here in central OK where we don't get too rough of a winter, ice storms notwithstanding.
Rain never seems to penetrate enough to be an issue.
Of course you're on your own for every rodent, varmint and insect that decides to take up residence.
The REAL Hal/WA
01-01-2008 18:53:37
When I was burning a lot of wood, I built a small pole building for wood storage. It is about 12'x16' and is tall enough so I could swing a splitting maul without problems inside. I covered the building with galvanized tin, with an area of greenhouse fiberglass sheeting for natural light inside. I never put a door on the building and never had any problems with moisture, since the wood was pretty dry before I stacked it inside.
I generally stacked about 5 to 7 cords inside in rounds and split the wood as I used it. At first I didn't have electricity to the woodshed, and used a gas lantern to split at night a few times, but later I ran an underground cable to give me lights and power in the shed.
Before I built the woodshed, I would stack outside in a large pile under tarps and up off the ground on pallets. That worked OK, except that during those years we got lots of snow. Hauling in wood was a big job--first the boys and I had to remove the snow to be able to get under the tarps. I don't know if the boys or I appreciated the new woodshed more! It also helped keep the wood much dryer, since there was no problem with blowing snow.
My woodshed didn't cost me much. The pressure treated poles were the biggest expense, since I got the metal from a neighbor for almost nothing. It had sat in a pile at his place for at least 20 years without being used and he just wanted to be rid of it. I did get a building permit, but would not bother now with something that small. I also got by without putting concrete around the poles, since it was so small. My sons and I built it over a couple of weeks of spare time.
We don't burn much wood anymore, since the natural gas line went down our road. When we built the new house, I didn't put in a woodburner. But that may change if gas gets much more expensive. I have mostly used the woodshed for storage the last years, but it is there, ready and handy if I decide to start burning wood again. I would say that building the woodshed was absolutely worth it and one of the best little projects we ever did. Good luck with yours!
Roy Suomi
01-01-2008 09:07:34
At least 2 sides should be open for air circulation..I would put it up against an existing building away from prevailing winds..This keeps most of the rain and snow off the wood pile ..I finally built a seperate room onto my barn for firewood..I had to break frozen wood apart for years..Enough is enough..
