Tractor Talk Discussion Forum
Case VAI Rear Axle Seals
Matthew J McNei
01-01-2008 10:27:27
Can anyone tell me where I can purchase a set of rear axle seals for a Case VAI? Thanks in advance for your cooperation.
Kestrel in CT
01-01-2008 13:21:21
 Re: Case VAI Rear Axle Seals in reply to Matthew J McNeill, 01-01-2008 10:27:27
I bought 2 last spring at a local bearing supply outlet. National Oil Seal # 455280 replaced original Case #VT3749
bradley martin
01-01-2008 12:45:22
Any Case dealer or any bearing supply source . You will need the original if sourcing other than Case or at least the OEM # so they can cross reference it.I don't have it handy, but if you posted this on the Case board, someone could likely give you the CR # or an equivalent,
