Tractor Talk Discussion Forum
Hey OLD
Larry59
01-05-2008 06:45:06
Was told it will be Monday for they have my tractor done. Cylinders on loader all repacked now. They found the lift in rear was low on hydraulic fluid and this was the problem cause of slant of hill not picking it up.
They are installing that new thermo-heater in water line for me also. That should help a lot on starting in cold weather.
At some point monday. The tractor goes to the muffler shop and a new stack will be made for it.
That exhaust running out from under the rear wheel was a killer when setting on it and not moving. lol
old
01-05-2008 09:41:10
 Re: Hey OLD in reply to Larry59, 01-05-2008 06:45:06
Thats good to here. That block heater will make it start up a lot faster if you remember to plug it in an hour or more before you want to use it.
KEH
01-05-2008 07:10:27
Larry,
Does that loader work off the tractor hydraulic pump instead of an external pump?
KEH
Larry59
01-05-2008 11:18:00
 Two pumps- Keh in reply to KEH, 01-05-2008 07:10:27
From what I was told.. it has the rear hydraulic and a front pump with reservior tank built in side arm of loader for the loaders use.
KEH
01-05-2008 13:26:51
 Re: Two pumps- Keh in reply to Larry59, 01-05-2008 11:18:00
O K, that should work better than just using the tractor hydraulics.
KEH
