Tractor Talk Discussion Forum
Farmall h Battery polarity
bdz
01-05-2008 14:59:34
is a 1947 farmall h a positive or negative ground
old
01-05-2008 15:29:01
 Re: Farmall h Battery polarity in reply to bdz, 01-05-2008 14:59:34
Depends on what might have been done to it over the years. If its 6 volts it should be + ground and when new it was + ground. But if its 12 volts you have a 99% chance its - ground and if you hook it up + ground then you will smoke test the alternator the moment you hook up the battery BTDT and learned the hard way and $50 later
Puller504
01-05-2008 15:10:36
Mine's positive. I learned that the hard way many years ago when Dad owned the H. Battery was drained one day and I hooked up the charger just like my truck, negative ground! Boy was Dad steamed as he had to go buy a new battery, seems I killed the one on the tractor! Don
