Tractor Talk Discussion Forum
9 bolt hub U Bolts??
PH
01-05-2008 15:07:38
What a day trying to move the wheels in on my oliver 77. The bolts were all rusty and seized into the hub. But when I removed the nuts they stripped. They are very corroded and I won't want to use them anyway. I have searched the net and can't find any to match my size. I probably have to have them custom made at a truck shop that bends u bolts. Have any other ideas??? The thread size is 3/4NF and the inside width is 2 1/2 wide and I can't remember how long.
gene beckham
01-05-2008 19:45:39
 Re: 9 bolt hub U Bolts?? in reply to PH, 01-05-2008 15:07:38
I've purchased u bolts from this place in Lebanon,mo .They will make them any size & they were not that expensive. 417-532-3167 & they came UPS Good Luck Wildman from MO
Don-Wi
01-05-2008 16:14:19
I had the same kind of fun on my 1600 when I narrowed it up. I let them soak over night, then soaked them again and went back to them a while later. I used heat, air hammer, and a BFH to get them off. Only ended up wrecking one.
I got the new one right from the dealer. Wasn't cheap, but for one it wasn't worth finding a truck shop that makes them. I replaced all the nuts with new (Fastenal), slothered anti-seeze on everything and tightened them back down where I wanted the hubs. The other 5 u-bolts were just fine. A little rusty, but not bad.
Donovan from Wisconsin
PH
01-05-2008 17:46:57
 Re: 9 bolt hub U Bolts?? in reply to Don-Wi, 01-05-2008 16:14:19
How much was the u bolt from the dealer?
Don-Wi
01-05-2008 22:15:43
 Re: 9 bolt hub U Bolts?? in reply to PH, 01-05-2008 17:46:57
To be honest I can't remember how much. I'm sure I could find it if I dug through all the papers I have from rebuilding the tractor, but it'd take a while. I do remember I was kinda surprised by the price, but for one I was willing to cough it up.
old
01-05-2008 15:32:33
Aren't they fun to move BTDT and have since found ways to do it and not work my butt off. Any how have you tried Korves #618-939-6681. He has lots of Oliver parts and if he doesn't have them he may know where to find them
marlowe
01-05-2008 15:13:13
you got it truck shop
glennster
01-05-2008 18:32:08
 Re: 9 bolt hub U Bolts?? in reply to marlowe, 01-05-2008 15:13:13
we have a shop near us that does leaf springs, they build their own there and make up u bolts too. spring-align is the name, maybe you have something like it near you.
