Tractor Talk Discussion Forum
Eagle hitch implements
Dalton S.
01-05-2008 22:32:37
How do u hook up implements to a case dc eagle hitch if the arms dont move? Does the implement have to be made from case for the eagle hitch? Thanks
jdemaris
01-06-2008 06:31:04
 Re: Eagle hitch implements in reply to Dalton S., 01-05-2008 22:32:37
I use standard three-point implements on all my Eagle hitchs (on my DCs and VACs). I suspect when the tractors were new it could of been a problem at times. But all my Cases have enough wear that allows the arms to swing sideways enough to hook up any Cat 1 hitch.
georgeky
01-06-2008 12:07:29
 Re: Eagle hitch implements in reply to jdemaris, 01-06-2008 06:31:04
My VAC which belonged to my grandpa, has had a 2 X 12 Dearborne 3 point plow on it since it was new. No problem at all.
jdemaris
01-06-2008 13:00:32
 Re: Eagle hitch implements in reply to georgeky, 01-06-2008 12:07:29
It all depends on the width. Some Cat 1 implements match the Case Eagle width and fit, regardless of wear or not. But, some others are wider and barely make it with worn Eagle arms. I've got a three-point scoop that is two inches wider than the Dearborn plow.
georgeky
01-07-2008 12:22:51
 Re: Eagle hitch implements in reply to jdemaris, 01-06-2008 13:00:32
I have gramps's scoop that he used on the Case. He turned the thing over when a rock came out of it as he was backing up. Most of his implements were converted horse drawn stuff that he made just for the Case, so he never had any problems with it.
in-too-deep
01-06-2008 05:53:51
Darn near every Eagle Hitch has been cut and welded to make the arm width fit typical implements. My dad's 400B was modified and it was still a pain to hook things up. It would probably be a fantastic hitch if you had a full-line of Eagle Hitch implements to go with it. Check to see if there's welds on your lift arms, if there isn't, you're either extremely lucky, or extremely unlucky.
Nebraska Cowman
01-06-2008 05:11:09
Yes, the width will have to match the arms.
georgeky
01-06-2008 00:59:01
The arms do move up and down just like any 3 point hitch. I have a VAC with eagle hitch, and use regular 3 point equipment on it. They just don't swing sideways like other 3 points do. The top of lift arm has a hinged latch that raises up to attach lift pins.
