Tractor Talk Discussion Forum
96 Ford F350 Powerstroke Waterpump big nut question??
John in Ct
01-10-2008 14:31:48
I have to get the big nut off on my 1996 Ford F350 with a powerstroke so I can take the waterpump off. It says "Right hand thread" on the shrowd. Before I break something, I want to make sure I know which way to turn the nut. Is it like a regular nut ora backwards nut? How do you hold the pully from turning? I got the special wrench to do the job. Thanks!!
Jerry Cent Mi.
01-11-2008 04:38:20
 Re: 96 Ford F350 Powerstroke Waterpump big nut question?? in reply to John in Ct, 01-10-2008 14:31:48
Some auto stores rent or loan the tools.
Mike M
01-10-2008 18:27:38
Sounds like the big nut on the Dodge fan clutches ? Leave the belt on and then get a big wrench and a hammer. Put the wrench on and give the end of it a GOOD WHACK in the direction you want to go. Lefty Loosey Righty Tighty.
glennster
01-10-2008 18:42:11
 Re: 96 Ford F350 Powerstroke Waterpump big nut question?? in reply to Mike M, 01-10-2008 18:27:38
the problem with the power strokes is you cannot get a regular wrench in there to get at the fan, with all the shrouds and stuff in there, the only way we found at the shop is to get the special wrench.
Bob
01-10-2008 15:05:29
Lisle makes a NEAT fan clutch wrench set, for use with an air impact hammer, so you don't have to try to hold the pulley!
Third Party Image
glennster
01-10-2008 14:56:44
them are a devil to get off even with the correct wrenches. here is a photo of our set for the powerstrokes, there is a spanner to hold the fan and the wrench to turn it. you can get the set from napa for about 80 dollars. its a gotta have for the powerstrokes. third party image
glennster
01-10-2008 15:01:25
 Re: 96 Ford F350 Powerstroke Waterpump big nut question?? in reply to glennster, 01-10-2008 14:56:44
be careful with the fan clutch its a 300.00 piece of metal!!!!
Bubba N (AL)
01-10-2008 14:47:22
Leaving the belts tight always worked for me GOOD LUCK Bubba
El Toro
01-10-2008 14:37:40
You need to turn the nut CCW to loosen if it has right hand threads. Hal
El Toro
01-10-2008 14:36:04
You may be able to use a strap wrench to hold the pulley. Hal
