Tractor Talk Discussion Forum
Massey 35 unstuck
Bob Bowers
01-11-2008 06:18:51
Through the forums here I tried the idea of Marvel mystery oil and diesel fuel. In a Massey I bought with a stuck engine. Mixed it up put it in the spark plug holes, jacked up one rear wheel, had it in 3rd gear. TWO weeks of adding contoction, and trying to turn the wheel when I walked by. It moved a little, more fluid It moved some more. I drained everything, new oil, plugs, wires, coil, points. It fired, Jesus there ant a skeeter left around here from the smoke. Clutch was stuck. Started it in gear and ran it around for ten minutes or more and the clutch came loose. It is smoking very little now. Did I miss anything? Or just run the heck out of it for a few days?
supergrumpy
01-11-2008 12:12:57
 Re: Massey 35 unstuck in reply to Bob Bowers, 01-11-2008 06:18:51
prior owner of my MF135 unstuck the engine by towing, he got it unstuck but tractor burned oil and ran awful, he finally tore down the engine and saw the broken rings and piston lands, thats why I have it
you did it the right way so maybe that kind of damage isn't there
wish I could have seen the smoke cloud
johnand cindy
01-11-2008 08:23:02
Do everything Mathais wrote work the tractor as Rich recomended than change oil again also change the trans and rear. Way to go!!!!! ! John
Mathias NY
01-11-2008 07:31:06
An engine oil change before running much would probably be a good idea. That way you can clear out any penetrating oil and debris that might be left over. Then change it again after a few more hours of operation to get rid of anything else that has worked its way free.
Congratulations by the way on your success!
Rich Va
01-11-2008 06:43:24
If you've got a plow or disk or something to hitch to and put it to work for a few hours or days that will help clean up that engine even more.
