Tractor Talk Discussion Forum
Water + in Tractor Tires
Wild Bill Caldw
01-11-2008 10:16:04
Thankin' all Yaw'l for the answers to the gas line question....Got another one for You.
I"m gonna put new rear tires on My '65 Farmall 504 Diesel. Mostly loamy soils, no GUMBO. Tire shop (rural area) said He'd fill the tires with anything I wanted....Water/antifreese, water/windshield cleaner, or?? Question is: knowin' what water weighs per Gal. and knowin' that weightin' tractor tires is not an exact science, How many gallons would You use. By the way, I'll be pullin' a 7 ft disc...A chisel plow I cut down to 8ft wide... a 3 bottom 14in. plow.
Wild Bill
ERP1233
01-14-2008 11:51:32
 Re: Water + in Tractor Tires in reply to Wild Bill Caldwell, 01-11-2008 10:16:04
i ALWAYS FILL THE TIRES COMPLETELY WITH WATER HOSE PRESSURE. I WOULD NOT OWN A TRACTOR WITHOUT WATER IN TIRES AS IT MAKES A HUGE DIFFERENCE.
I LIVE IN LOUISIANA AND IT GETS TO 26 DEGREES F. HERE AND IA HAVE NEVER HAD TO USE ANTIFREEZE SOLUTION OF ANY KIND. (NOT SURE WHERE YOU ARE LOCATED.)
DiyDave
01-11-2008 15:44:08
I always use methanol in tires as ballast. Reason why follows the end of the free story: I had a John Deere 440 industrial tractor with a loader, and a backhoe subframe(bought in one of my younger, weaker mental moments). I needed a backhoe to clean out the overflow of our farm pond, as some fill dumped carelessly by a contractor had jammed up the overflow pipe at the discharge end of the pipe. As I had a limited budget at the time, I found a Ware backhoe off of a 953 Cat at a bargain basement price. Being handy with a torch, and having a good eyes at the time, was able to adapt one to the other, even though the backhoe far outweighed the loader(I needed an 800 lb counterweight in the bucket, just to keep the front end of the contraption on the ground[intermittently]). Anyway there I was proud as can be driving back up the driveway, having finished the job on time, on budget, on the way to disconnecting the world's largest example of I.P. engineering, when I heard a click, and felt the right rear fender vibrate a little. Naturally, I slowed the wheelie machine down , and looked to see what was caught between the fender and wheel on the right side, as I heard the click, and felt the vibration again. Didn't see anything till the tire with the split sidewall and rapidly prolapsing innertube hit the fender for the third and final time. As I saw what was going to inevitably going to happen, I closed my eyes, and uttered a few choice words, and as about 80 gallons of methanol hit me in the face, head and shoulder, I thought, hey this sure tastes better than calcium chloride!
Gerald J.
01-11-2008 15:01:56
A few years ago, one of my MF-135 rear tires split the sidewall a little, then pinched the tube and squirted CaCL over me and the tractor. The tractor rusted instantly even though painted. My jeans stood up by them selves that evening.
I swore off CaCl in tires at that point. Put on new tires and they pulled the plow and disk better by having sharp corners on the lugs than the old tires did. I'm not putting liquid in my tractor tires again.
The CaCl is the lowest cost option, but the hardest on the tractor. If you think they will never freeze, water will do. Antifreeze or windshield wiper solution doesn't to the rot that CaCl does. Typically a tire is considered "full" if the liquid is up to the top of the rim. Needs the rest as air to have some cushion.
There is also a product called "Rim Guard" made in Michigan from beet juice. Sit down before you ask the price.
Gerald J.
Gun guru
01-11-2008 14:49:43
Water weighs in at 62.4 pounds per cubic foot, which is about 7.5 pounds per gallon.
Fordfarmer
01-11-2008 10:29:09
Plain water is about 8 lb./gal. CaCl solution can be varried, but is usually 12 lb./gal. to make sure it's strong enough to not freeze. I would expect windshield washer fluid to be around 8 lb./gal. AS far as how many gallons to use, any tire shop that provides this service should have a chart showing how many gallons a given tire size can hold. This is "unsprung" weight, meaning your tractor's axles don't carry it, so you don't have to worry about overweighting it in that resect.
glennster
01-11-2008 10:20:08
here is a link to a tire ballast chart for chloride, it gives the tire size, weight with just water and then with the calcium mixed in. you can ballpark your weight from there.i run 5lb per gallon mix to load em heavy.
tire chart
