Tractor Talk Discussion Forum
1 wire alternator
Dan in Ore
01-12-2008 16:07:22
I just purchase a 1-wire alternator. My question is where do I go with the hot wire? I don't have an ammeter in the system.
Dan
guido
01-15-2008 10:51:41
 Re: 1 wire alternator in reply to Dan in Ore, 01-12-2008 16:07:22
Hey Dan.
The one one is for the battery connection, and you are done.
Guido.
guido
01-14-2008 15:54:55
Hey Dan
If you need to monitor your battery's state of charge you need a volt meter. The amp meter will only show the amount of charge going into the battery, while the volt meter will tell you how much voltage/potential IS in the battery.
A/c generators/alternators generate as much as 1/3 the rated output at idle, REGARDLESS OF CONSTRUCTION or # of wires.
GUIDO.
buickanddeere
01-12-2008 18:35:28
Install an ammeter or wish you had. They are cheap and reliable too.
ric1
01-12-2008 18:12:08
i got a 1 wire one a to30 no problem soon as she fires up i rev her up just a little and the ol amp meter starts showing charge works great actually
john in la
01-12-2008 17:14:01
The wire needs to be 10 gauge and gets hooked where ever the + battery cable hooks. Starter; starter solenoid; battery post; ect.
If this is the Delco 10si alternator; I will have to agree with the other post. You will most likely be back in a few weeks asking how to re-wire it with 3 wires because it will not charge until you rev the engine to full throttle. Once it starts charging it will charge well but getting it to start can be a problem.
Now do not get me wrong. They do make a true one wire 10si. It was used in marine situations and cost over $80 for a rebuilt unit. But since the common three wire alternator will work as a one wire with the full throttle treatment; most said to be one wire alternators are really not.
moonlite 37
01-12-2008 16:30:49
I cannot see any good reason to use a one wire. I have had a couple but since I learned how to wire the others I have found that the one wire need more RPMs to start charging.
marlowe
01-12-2008 16:51:45
 Re: 1 wire alternator in reply to moonlite 37, 01-12-2008 16:30:49
then how ever your getting them from are not putting in a low speed starter
bradk
01-12-2008 17:47:30
 Re: 1 wire alternator in reply to marlowe, 01-12-2008 16:51:45
We have several 1 wire alts. in tractors and have no problems with them.They kick in at fairly low RPM.
I have heard of battery drainage over long periods,but a remedy (diode) is easily installed inline if needed. ~brad
soundguy
01-14-2008 04:41:26
 Re: 1 wire alternator in reply to bradk, 01-12-2008 17:47:30
IMHO, a manual battery disconnect switch is a better idea than adding a diode in the charge line on a 1-wire setup.. etc.
soundguy
Greg_Ky
01-12-2008 16:25:21
Anywhere that goes to the battery (Non switched)
