Tractor Talk Discussion Forum
plugs.
Farmallken.
01-12-2008 16:25:01
Hi Guys.
What spark plugs do you guys use in your farmall H tractors. Thanks again for all the help. Ken.
Andy Motteberg
01-12-2008 18:29:36
 Re: plugs. in reply to Farmallken., 01-12-2008 16:25:01
I use Autolite 3116 plugs. They are non-resistor plugs and work much much better than any other plugs I've ever used.
Steven f/AZ
01-12-2008 17:16:03
Depends on how hard you're going to use it.
I'm running Champion D18 or D19 I think and have no troubles because I work mine pretty hard.
D21 are hotter plugs that are good for idling around the yard or just cruising around...
Dave_Id
01-12-2008 16:43:51
For not so good engines, I use Autolite 1186 or Champion D21. They are a little hotter plug. Normal engines, Autolite 386, the Champion equivalent to that would be D15, or D18 would be slightly hotter
RustyFarmall
01-12-2008 18:55:05
 Re: plugs. in reply to Dave_Id, 01-12-2008 16:43:51
Autolite 388s are equivalent to Champion D-21s.
buickanddeere
01-13-2008 00:01:26
 Re: plugs. in reply to RustyFarmall, 01-12-2008 18:55:05
Nope, 388's are resistor and the D-21 are none resistor. 378 and D-21 are similar Unless you are using a Ham Radio on that tractor, listening to AM radio or takeoff & land at busy airports. Use none resistor plugs and solid core wires.
RayP(MI)
01-13-2008 14:32:42
 Re: plugs. in reply to buickanddeere, 01-13-2008 00:01:26
Buickanddeere - QRZ? de WB8VWK .... and yes, our's get ham radio from time to time! (Wonder why they're all converted to 12v?)
