Tractor Talk Discussion Forum
Jump starting... hoses?
Kent in KC
01-14-2008 08:23:03
Anyone ever think about putting quick connects on your equipment's cooling systems, heater hoses, etc. so you could plug a running vehicle up to one that's too cold to start? Seems like you could circulate hot coolant through the cold machine and thus get er going easier.
teddy52food
01-14-2008 17:58:20
 Re: Jump starting... hoses? in reply to Kent in KC, 01-14-2008 08:23:03
The loggers do it all the time in northern Minnesota. They have couplers on the pickup and on the skidder (Diesel) that is left in the woods overnight.
matthies
01-14-2008 17:33:36
Kent were you the guy looking for the solenoid valve on the carb of a JD 4020/3020? And did you find one, I finally found mine if you still need it. chris
nw_bearcat
01-14-2008 15:14:44
Isn't that a problem w/ the newer pickups since they have the X-life antifreeze?
back 10-15 years ago, alot of the dozer/loggers even down in Northern MO had those plumbed into their pickups, but not so much any more w/ the newer motors.
Jim WJ
01-14-2008 14:41:57
That setup with the coolant hoses works well in northern mn. also. We' were doing this up until about two years ago. Then we switched over to the small programable heaters that run on diesel fuel. Jim WJ
Hoss in Maine
01-14-2008 13:43:38
Yep,we do it all the time up here in Maine.Gets down 0 to 30 below you need them hoses on skidders.Log trucks stay plugged into an electrical outlet all night,fire right up with no either. Later Hoss
Kent in KC
01-14-2008 11:45:05
I figured someone had already tried it.
rrlund
01-14-2008 11:37:03
Saw a set up like that advertised in a magazine not too long ago.
RobMD
01-14-2008 08:51:52
yep, only if you're far north, though
M Nut
01-14-2008 08:51:49
Only way to start Logging Equipment here in MN. Works good. I have heard concern about cracking the heads or blocks of pickup motors due to the cold anti-freeze from the machine coming into contact with the hot pick-up motor, but I don't know of anyone who has actually had a problem.
marlowe
01-14-2008 08:46:10
we have just about all our construction Eq set up with quick heats safer then propane heaters takes about 20 minn. to heat up a big Cummings all my pickups have plug ins and all my loaders sit out side all over the place for snow removal in the winter so we can't use propane heaters because people steel the tanks
Gary in da UP
01-14-2008 08:44:27
That method of pre heating is common here in Michigans UP, Skidders and other logging equipment left in the woods over night crank right up!
Allan In NE
01-14-2008 08:25:56
They do that up north all the time. It gets cold up there. :>)
Allan
